Home Forums Products Stompboxes H90 algorithms doesen’t detect stereo signal from stereo loop Reply To: H90 algorithms doesen’t detect stereo signal from stereo loop
#176576
Robjob223
    I believe I’m having the same issue with the latest updates (Bluetooth etc.).  Have a Strymon Dig in stereo loop:  Signal path is
    guitar -> h90 input 1 ->     H90 outputs 3&4 UA amp sim -> to Dig, dig outputs to h90 inputs 3 & 4, h90 outputs 1&2 -> …
    Have a variety of patches with stereo insert , either series pre A, series mid.  IIRC I was having similar issues with parallel routing too, but definitely unexpected behavior in the series pre A configuration as detailed below.
    1. Programs with the stereo insert pre A:
    When both effects are engaged only one side of the ping pong delay can be heard and its panned center.  When A is bypassed and B engaged, the series ping pong mode functions properly.
    2.  Programs with stereo insert mid:  Everything works as expected
    So there is definitely something going on with stereo insert behavior when placed Series Pre A, as engaging/bypassing A changes what’s going on with the insert.
    Going to experiment with whether using an LS-2 to split from guitar into both H90 inputs 1 and 2 will be a workaround, but curious as to whether OP and I are misunderstanding something or if others are having same issue.
