Home Forums Products Stompboxes Confirmation of stereo inputs Space/PitchFactor Reply To: Confirmation of stereo inputs Space/PitchFactor
#176580
Thanks, I think I may be able to reproduce what you are seeing in certain situations. It seems like this will happen when a constant tone is being fed into the signal path, and the display of one side of the input meters will glitch a bit. If I am sending a typical audio source with dynamics, this is not happening for me.
Most importantly, I am not hearing any issues with the audio or stereo image of the signal when this happens. Can you confirm if you are noticing anything incorrect about how the audio sounds, or are all these test just visually looking at the input meters in the app?
There may be an issue with the meter display in H9 Control, but as far as I can tell, there is no issue with the audio or performance of the pedal.
