Home Forums Products Plug-Ins Blackhole/MicroPitch not showing in Logic Reply To: Blackhole/MicroPitch not showing in Logic
#176612
Sorry you are still having issues. What happens when you click one of the Immersive plug-ins and select “Reset & Rescan select”? Are there any error messages or does it validate correctly?
Please try the following steps:
  • Close Logic Pro X
  • Make sure Finder is the active application
  • While holding the Option key, click on the Go menu at the top of your screen and select Library
  • Delete the following files from your User Library, if they are present:
    ~/Library/Caches/com.apple.audiounits.cache
    ~/Library/Caches/AudioUnitCache/
    ~/Library/Preferences/com.apple.audio.InfoHelper.plist
    ~/Library/Preferences/com.apple.audio.SandboxHelper.plist
  • Then, open a Terminal window (located at Applications/Utilities/Terminal), and enter the following commands (type each command and press “Enter” afterwards):
    • killall -9 cfprefsd
    • killall -9 AudioComponentRegistrar
  • Restart your computer
  • Restart Logic Pro X
