Home Forums Products Stompboxes H90 algorithms doesen’t detect stereo signal from stereo loop Reply To: H90 algorithms doesen’t detect stereo signal from stereo loop
#176620
Thanks for reporting this. I can reproduce what you describe and this does not seem like the correct routing behavior.
We’re looking into a fix for this and I can let you know when that is available. For now, I would suggest that to use your setup with a stereo input into the H90 since the issue does not occur with that routing. Sorry for the inconvenience.
