Home Forums Products Stompboxes H90 Feature request: More more effects at once in the chain Reply To: H90 Feature request: More more effects at once in the chain
#176723
ndeshpande
    Yeah, its a pity the EQ has to take up one slot. A simple high pass & low pass in the pre section would be amazing. The delays don’t have dampening or eq like Boss DD. The high end can tend to run away in the fx section – what about an H3000 mode that cuts from round 10k?
    Some of the TimeFactor algorithms and MicroPitch have damping filters in the feedback section. If you need both a low cut and a high cut, the Vintage Delay algorithm is a dark horse as the filter knob has two filters running in the feedback loop; I find Vintage Delay with bits set to 11-13, depth set to 2, rate set to taste, and filter in the 25-45 range gets an ethereal float…
    The tone knobs in delays that go +/- do cut up high if you turn the knob in the right direction. Look at Digital Delay and Mod Delay in particular (plus MicroPitch, which is more than just a detuner…). I also find that setting the mode on H910/H949 algorithm can be used to dial in the top end…
