Home Forums Products Stompboxes swell or violoning effect with the H90 Reply To: swell or violoning effect with the H90
#176815
    There is an UltraTap preset called “Ultraswell” that should do the trick.
    You can also check out the new PolySynth algorithm and that can give you some violin swell style effects. Start with the “PWM Strings” preset, turn the attack up for a slower swell, and adjust the filter cutoff/resonance to taste.
