Home Forums Products Stompboxes swell or violoning effect with the H90 Reply To: swell or violoning effect with the H90
#176824
    PolySynth is a good route to take, but don’t give up on UltraTap (or DynaVerb) just yet.  Here’s a little “test” Program I just put together:
    https://www.dropbox.com/scl/fi/44ap1ndcafjgve75ac2e9/UltraTap-DynaVerb-Swells.pgm90?rlkey=s1mr133ejndeyxq3rywsi40kb&raw=1
    UltraTap & DynaVerb in parallel.  You can bypass either one in the Performance Switches, or dial the (P) Hotknob to 0 OR 100.
    Everyone’s playing style and system specifics are different.  So the critical adjustments will be:
    • The threshold level where the swell will be triggered.
    • The time it will take to swell to full volume.
    • How long it will take to release that for the next swell trigger.
    I mapped the other two HotKnobs to some of those parameters, to make it easier to adjust.
    • (A) HotKnob – UltraTap (Chop) Swell sensitivity & Rise time
    • (B) HotKnob – DynaVerb Threshold level & Release time
    I added a few bells ‘n’ whistles to experiment with (expression pedal swells, HotSwitch options for simulating ensemble swells, using diffusion & reverb).
