Home › Forums › Products › Stompboxes › H90 Wah with expression pedal over midi › Reply To: H90 Wah with expression pedal over midi
January 9, 2024 at 6:53 am
#177151
I would not say useless! In the end you have a good Wah-Effect…
I wanted to buy the Mission Engineering SP-H9-WH … would be a solution because of the toe-switch. But Expression+Toe-Switch won’t work 🙁
That would be a great move to make that work (I understood i worked on the H9?)
Anyhow… to make the “on/off” on the expression pedal variabel would be even better… I could think of some applications for this but Wah and Filter are the main ones.
