Home Forums Products Eurorack Modules Misha clock PPQ and t/g output questions Reply To: Misha clock PPQ and t/g output questions
#177190
    You’re welcome.
    Using an external clock with PPQ set to 1 and clock divider at 1/4, the sequence advances every time Misha receives a single clock pulse, and will also output a t/g for every pulse. The output will remain high until Misha receives the next clock pulse, and then it will retrigger. This is how it is working with my setup.
    Could you please make a short video showing what you are describing? It seems that we are not experiencing the same thing if you say the output goes high and stays that way indefinitely. It should be retriggering for every clock pulse received.
