Home › Forums › Products › Eurorack Modules › Misha clock PPQ and t/g output questions › Reply To: Misha clock PPQ and t/g output questions
#177192
dave999z
    Certainly, I will make a video and post back here.
    One interim question… it’s labelled a “t/g” output, but those are technically different things.  Does Misha make any distinction between a trigger and a gate?  I wonder if my envelop generator module (only one I have tried with Misha so far is TipTop/Buchla 281t) expects only a quick trigger pulse, whereas a gate that stays high for the duration of the note and then only drops low for a tiny moment before going high again is not working to retrigger the envelope.
    In other words I wonder if the issue is the difference between…
    quick trigger (mostly stays low, briefly goes high):
    ____-_______-________-________-________-________-_____
    versus gate (mostly stays high, briefly goes low):
    —-_————-_————_————_————_————_——
    When I make the video I’ll also try sending Misha’s t/g to a different envelope generator module in case that’s the culprit.
