Home › Forums › Products › Stompboxes › MIDI expression issue and bricking › Reply To: MIDI expression issue and bricking
January 12, 2024 at 4:50 am
#177245
I’m having the same problem, is there a solution?
If not I’m starting another thread. It used to work perfect until updating to 1.6.1, tried 3 different exp pedals, different cables, over midi (also tried 14-bit), direct analog into H90; problem stays. If I move the pedal slowly, you can hear the steps, if I move it fast its more a on/off behaviour instead of a sweep.
