Home Forums Products Stompboxes H90 – Two scale in one programs – one click footswitch Reply To: H90 – Two scale in one programs – one click footswitch
#177246
marianguitar
    Hello, I set it up as you wrote, but somehow it doesn’t work for me. You probably need to set the assignment of the Hot switch, please, what should I set there (there is only an English manual and I go through everything through a translator).
    Zdravím, tak nastavil som to ako ste písal, ale nejako mi to nefunguje. Asi treba nastaviť aj priradenie Hot switchu, prosím, čo tam mám nastaviť (je len anglický manuál a ja všetko idem cez translator).
