Home Forums Products Stompboxes Insert Location Setting Help Reply To: Insert Location Setting Help
#177424
joecozzi
    When using another pedal routed in / out of the H90 as an insert, are you able to set the location of that insert differently per preset (and have it therefore be midi foot-switchable), or will the insert location setting be Global only?…Can that insert location be programmed PER PRESET, or is that location a global-only setting?
    Yes, insert position is stored on a Program basis as you described. There is no global setting for inserts, only routing modes.
