Home Forums Products Stompboxes H9 Output from second loop (second I/0) Reply To: H9 Output from second loop (second I/0)
#177847
joecozzi
    I always recommend to check your cables in isolation. Make sure they are working properly.
    Also, can you verify the Routing mode you are using on the H9? it should be set to “Normal” as opposed to “pre-post.”
