Home Forums Products Stompboxes optimal current / voltage H90 Reply To: optimal current / voltage H90
#177882
joecozzi
    Cioks power supplies can effectively handle the startup spike the H90 requires during power cycling. A 1 Amp power supply simply provides a much safer rating. Even though you’re very close to the absolute minimum power requirements of the H90 with one outlet of the Hi5, there is no audible difference running it higher.
