Home › Forums › Products › Stompboxes › H90 and HX Stomp power supply › Reply To: H90 and HX Stomp power supply
#178064
joecozzi
    Eventide PowerMini: https://www.eventideaudio.com/pedals/powermini/
    You would be able to power the H90 with one outlet running at 12V and the HX stomp with two outlets at 9V using a combination of these two cables:
    Flex 8800: https://store.eventideaudio.com/collections/cables/products/8800-parallel-adapter-flex-10cm-sand-grey
    Flex Type 3: https://store.eventideaudio.com/collections/cables/products/3050-flex-type-3-5-5-2-5mm-dc-plug-center-negative-angled-l-shape-50-cm
