Home › Forums › Products › Stompboxes › H90 insert loop latency › Reply To: H90 insert loop latency
February 12, 2024 at 11:26 am
#178134
The latency of the H90’s main path is dependent on the preset routing; Series: ~4.5ms and Parallel: ~3.8ms.
Each Insert will add an additional ~3.8ms of latency, plus any additional latency compensation specified in the Insert settings.
Program and Preset level parameters such as mix, bypass, kill dry, and bypass mode do not contribute to the total latency.
