Home › Forums › Products › Stompboxes › H90 insert loop latency › Reply To: H90 insert loop latency
#178143
apalazzolo
    Is there a latency difference in the main signal path between these three scenarios?:
    1. Slots A and B are in series and both are running presets.
    2. Slots A and B are in series and one slot runs a preset while the other is a non-bypassed “INIT Program”.
    3.  Slots A and B are in series and one slot runs a preset while the other is a bypassed “INIT Program”.
    I’m trying to understand if can reduce latency by not using one slot and, if so, do I actually need to bypass an “unused” slot to do that.
    Thanks.
