Home Forums Products Stompboxes H90 Routing Question Reply To: H90 Routing Question
#178252
    If only one Preset is on either path (pre/post mode), then there is nothing for either Preset to run parallel against. There needs to be two presets on one path for them to be able to run in parallel.
    If you turn the Program Mix to 50% you will preserve your dry signal if you’d like finer control between the dry signal and the Phaser.
