Home Forums Products Stompboxes H90 Routing Question Reply To: H90 Routing Question
#178255
    No need to apologize, happy to answer questions. The Program Mix will be for both Path 1/2 (and both Presets).
    Sorry, I don’t think we’d be able to add this feature as it would required adding an additional mixing block. Mixing the dry signal with the modulated filters is essential for a phaser effect and that’s why there is no mix parameter. You may find that turning down the Intensity or Depth on Phaser or Instant Phaser will give you a less intense phaser effect. You can also try Even-Vibe or TriceraChorus with Swirl on for a different modulation flavor that may be better for what you’re trying to achieve.
