Home Forums Products Stompboxes H90 MIDI/Programming Questions Reply To: H90 MIDI/Programming Questions
#178274
    Hello. Can you be more specific with what the issue you are having is?
    The Playlist will always be 99 Programs, but if you have Programs 1-55 consecutively, you will only need to increment+load once for each Program to go up the list.
    Is the issue you are describing due to having many INIT Programs between the 55 Programs you are using?
