Home Forums Products Stompboxes H90 MIDI/Programming Questions Reply To: H90 MIDI/Programming Questions
#178276
    In Bank Mode, you can hold the P footswitch and it will take you back to Bank 1. I would suggest using your MIDI controller to Bank up/down, and using the H90 footswitches to select from one of the 3 Programs using the P/A/B footswitches. Then, you can hold the P footswitch to get back to Bank 1 when needed.
    If your list is not optimized because there are INIT Programs in between the other Programs you are using, the only thing that can be done is organizing your list in a better way. Using H90 Control for this makes it very easy to adjust the order of your Programs.
    Let me know if that helps.
