Home › Forums › Products › Stompboxes › Boss ES-8 tuner out into H90 › Reply To: Boss ES-8 tuner out into H90
February 17, 2024 at 5:28 pm
#178306
Is the tuner on the H90 set to MUTE? What version of the H90 software are you running?
I’m using the latest firmware for the H90.
The H90 tuner is set to mute and does mute the wet signal. The dry signal goes out to an amp before ever getting to the H90, so there’s no way for it to do anything with that, which is why I’d like to use the tuner out feature of the ES-8 and mute from there.
