Home Forums Products Stompboxes Assigning freeze to hot switch- Space Reply To: Assigning freeze to hot switch- Space
#178315
joecozzi
    To Enter/Exit System Mode
    Press and hold the Encoder and Right Footswitch simultaneously for a few seconds to enter and exit the System Mode. Upon entering System Mode, you’re at the top-level menu selection. The Left and Right
    Footswitch LEDs will flash RED continuously to remind you that you’re in this special mode.
    Go into the Utility menu and you’ll find the serial number option.
