Home › Forums › Products › Stompboxes › knob programs › Reply To: knob programs
February 18, 2024 at 3:45 am
#178325
As I understand it, if you specify a change to this or that parameter that can be linked, you will not be able to specify this or that handle?
For each knob, you cannot specify any of the parameters in a certain order… assign a damping knob – resonance, and so on… but use only the established algorithm, choosing the convenient installation of certain options on the knob and changing only the values of the numbers, these parameters Are you satisfied with the save… did I understand you correctly?
