Home Forums Products Stompboxes H90 insert loop latency Reply To: H90 insert loop latency
#178376
matfagan
    Perhaps I should clarify, I’m not ‘blaming’ Eventide. They’ve done an amazing job with the h90, and I understand that latency is something that comes with ADA conversion.
    As Infection noted earlier, ‘people are different’. I’m not sitting in my bedroom making ambient soundscapes, I play in all kinds of performance situations.
    I posted here looking for a solution, or advice on how to minimise the issue. It needs to be said, the h90 has retired around a dozen pedals I’ve been swapping in and out for years depending on the gig, and now it’s all there in one unit. Incredible stuff, however…
    If the ability to move pedals around in the signal chain is important to someone considering the h90, they should be aware it’s not flawless in its application.
