Home › Forums › Products › Stompboxes › syncing H9 and H90 with tap tempo › Reply To: syncing H9 and H90 with tap tempo
March 11, 2024 at 12:12 pm
#179155
Ok, glad to hear some progress is being.
Does the MIDI input on the H9 work when you send a PC message from the H90?
Make sure the MIDI channels are the same on both devices and that the H90 has transmit ON. If you load any Program on the H90, this will send send a PC message and should change the preset on the H9.
