Home › Forums › Products › Stompboxes › syncing H9 and H90 with tap tempo › Reply To: syncing H9 and H90 with tap tempo
#179271
d.talma
    Hi again, well, it seems that the midi input of the H9 is simply not working. I sent some PC from ProTools, if I send them over USB they H9 responds, if I send the same PC over MIDI, the H9 does not respond. So… I did a reset the H9 to factory, re-did all the settings, and wow, now it is working!
    Thanks for all your help!
