Home Forums Products Stompboxes syncing H9 and H90 with tap tempo Reply To: syncing H9 and H90 with tap tempo
#179277
    … if I send them over USB they H9 responds, if I send the same PC over MIDI, the H9 does not respond. So… I did a reset the H9 to factory, re-did all the settings, and wow, now it is working! …
    Excellent.  And baffling, because it seemed like you were taking all the right steps.  It was working here, so what could be different?
    One thing to look out for, and this gets everybody at one point or another:  The H9 USB will override the MIDI DIN input, when USB is physically plugged in.
    In other words, DIN can stay plugged in & active as long as it’s by itself.  Plug in USB, and it takes over the duties of MIDI DIN.
