Home › Forums › Products › Stompboxes › syncing H9 and H90 with tap tempo › Reply To: syncing H9 and H90 with tap tempo
#179278
d.talma
    Thanks for the heads up, that was something I indeed discovered along the way, while I was testing the PC. That is a bit confusing, and unexpected, but on the other hand maybe logical… The funny thing was that I don’t want the PC to work, and those never worked when I was setting up the clock, so the midi input was apparently in a ‘confused’ state.
    I now switched receive omni off on the H9, and set PC to receive on channel 16, while the H90 sends them on channel 1. So the PC do not arrive, and the clock does, so now I can use them independent, but at the same time have all time based effects in the same tempo, which is really cool.
    Very kind of you to help diagnosing the problem.
    Daniel
