Home Forums Products Stompboxes Mixing link possible use? Reply To: Mixing link possible use?
#179698
Oats
    Thanks for the timely response! A few more quick questions if I may- would setting it up as you suggest enable me to kill the “dry” channel with the footswitch? Also, in this setup do I need to worry about phase? I.E. should I make sure my line isolator can change the phase of one of its channels? Or is that not a concern with this setup? And finally does this whole idea for w\d\w seem viable or problematic? Seems enticing on the face of it to do w\d\w with one amp but sometimes things are a lot harder than they look! I appreciate your input!
