Home Forums Products Stompboxes Mixing link possible use? Reply To: Mixing link possible use?
#179808
    You’re welcome.
    • The “dry” channel in this setup is your guitar amp. This will not be muted when you deactivate the FX loop using the footswitch. The “wet” signal will be muted when you deactivate the FX loop using the footswitch.
    • If your dry and wet signals are completely separated (wet signals are fully wet or using kill dry) you most likely will not have issues. In most scenarios, phase can be flipped using the mixing board if necessary.
    • With a good live engineer who can give you the correct mix of wet/dry signals, this should be a nice setup.
