Home Forums Products Stompboxes H90 settings to replicate DD-3 settings? Reply To: H90 settings to replicate DD-3 settings?
#180468
    … Can someone help me to replicate these settings, it seems I can’t select a normal Algorithm and start a new sound. I have to start using the eventide presets…
    I can give you a place to start.  Yes, load up any Preset from Delay -> Digital Delay.
    Adjust the settings on that one, rename it, and Save (To Library) as a new Preset.
    For the settings below with a range of values, adjust those by ear.
    • MIX – 10-20 [DD-3 E. Level MAX is about 50% on Digital Delay MIX]
    • DELAY MIX – A10-B10
    • DELAY A – looks to be around 500-600 mS in the DD-3 800 range.
    • DELAY B – set this to the same value as DELAY A.
    • FEEDBACK A – 15-25
    • FEEDBACK B – set this to the same value as FEEDBACK A.
    • X-FADE – 75-125 mS
    • MOD DEPTH – 0
    • MOD RATE – 0
    • FILTER – 0-20
    For the DD-3 HOLD function, you can experiment with REPEAT (L) and REPEAT (M) under the PERFORM mode.
