Home Forums Products Stompboxes After 5.2.0[6] update, FactorLib thinks ModFactor is a TimeFactor Reply To: After 5.2.0[6] update, FactorLib thinks ModFactor is a TimeFactor
#180475
tsternfeld
    I’m sorry you’re having trouble.
    The FactorLib Preset Librarian is no longer supported. After installing a v5 software release on your TimeFactor pedal, you can now use H9 Control instead to manage your presets and preset lists.  To upgrade your TimeFactor to a v5 release, please download, install and open H9 Control with your TimeFactor connected, and it will guide you through the upgrade process.  If you had saved presets earlier using FactorLib, H9 Control can import these FactorLib preset files so that they can be used inside H9 Control. To import a FactorLib preset list into H9 Control, just drag and drop the syx file onto H9 Control. Your imported presets will be accessible both as individual presets under H9 Control’s Preset section and as a preset list under H9 Control’s Preset List section.
    Hope that helps.
