Home Forums Products Stompboxes Recommended expression pedals for H90 Reply To: Recommended expression pedals for H90
#180973
paulmarshall
    OK I’ve sorted out how to connect the Mission SP-25L-PRO to the H90. The footswitch is the TRS output on the right hand side. I used the Y-splitter I had spare and connected the tip to exp 2. Then I connected a standard TRS to exp 1 from the sockets on the left hand side. Go into System IO and select exp1 and sw45 and everything is fine!
