Home Forums Products Stompboxes A/B Mix Explanation? Reply To: A/B Mix Explanation?
#181000
Fox Uncle
Thanks Brock! That’s helpful. I did read the manual section, but I was confused by one thing. Here’s the excerpt that confused me with an explanation as to why I was confused, below:
<span style=”font-size: inherit;”>With stereo outputs, you may turn [A/B Mix] parameter fully clockwise for dual mono reverbs (A on left, B on right). A mono input will be sent to each reverb, while a stereo input will send input 1 to reverb A, and input 2 to reverb B.
</span>
What confused me about that is that my source is mono but dual mono actually sounds less wide or “less stereo” than A/B Mix settings more toward 12 O’Clock. It sounds like it’s dividing the signal reverb between the two channels more when it’s not in dual mono, with a mono source.
