Home › Forums › Products › Stompboxes › A/B Mix Explanation? › Reply To: A/B Mix Explanation?
April 15, 2024 at 9:15 pm
#181040
Dual Mono Dual-DualVerb
Insert Mode Program with two DualVerb instances side-by-side in Parallel.
- Preset (A) – A/B Mix at A10+B10 (Active default)
- Preset (B) – A/B Mix at Dual Mono (Bypass default)
- Switch between Act/Byp for either Preset (or both Active).
To better hear the separated reverbs, I used 450 & 900 ms Pre Delays in both instances.
- Defeat all Pre Delay with HS1.
I exaggerated the Tone A / B differences in each DualVerb instance to differentiate between reverbs.
- Adjust Tone A / Tone B with (A) & (B) HotKnob.
- HS2 sets all Tone controls to flat.
HS3 flips the Pre Delays in DualVerb-1, also setting it to Dual Mono. Four 50 second reverbs to audition the wide separation.
(P) HotKnob adjusts Decay A & Decay B in both instances, from 0 ms – 50 S + INFINITE & FREEZE.
- EXP1 is mapped to the (P) HotKnob above.
- EXP2 is mapped to A/B Mix in both DualVerbs (saved at A10+B10).
