Home Forums Products Stompboxes Is there a way to map parameters to Hotswitches using H90 Control Software? Reply To: Is there a way to map parameters to Hotswitches using H90 Control Software?
#181178
brockstar
    https://cdn.eventideaudio.com/manuals/h90/1.8.5/content/h90-control/edit.html#parameters-edit-menu
    See 18 – “Select HotSwitch 1-3, and edit parameters for the selected HotSwitch.”
    Look at the bottom right corner of the H90 control app under parameters tab and you’ll see PGM-HS1-HS2-HS3
    PGM is the program you’re on
    Click HS1 and then change whatever knob or knobs you want
    Click HS2 and then change whatever knob or knobs you want
    Save your program and those hotswitches will be like you set them under each one.
