Home Forums Products Stompboxes Routing: multiple inputs to the same processing path Reply To: Routing: multiple inputs to the same processing path
#181202
    You can use Insert routing to use the H90 as a mixer. You can watch this tutorial for more information: https://youtu.be/0G_WtfUatSc?si=DXefUjr4-4XaXIW7&t=1190
    You can turn Force Mono on and this will make output 1-2 a dual mono pair with the same signal on both outputs.
