Home Forums Products Stompboxes CC control of H90 Insert bypass / active Reply To: CC control of H90 Insert bypass / active
#181459
joecozzi
    if I bypass the Insert whilst using one preset, if I then switch to a different preset in which I want the default to be that the insert is active, this doesn’t happen; the insert stays bypassed until I send a second momentary CC message.
     May I have some clarification here? How are you switching presets? Are you doing it manually? Did you mean switching Programs?
