Home › Forums › Products › Stompboxes › H90 double the outputs › Reply To: H90 double the outputs
May 3, 2024 at 10:38 am
#182003
That is correct, a small amount of latency will be introduced from the insert routing. Specifics can be seen here: https://cdn.eventideaudio.com/manuals/h90/1.8.6/content/appendix/specifications.html
Sorry if this does not work for your setup.
