Home Forums Products Stompboxes H90 double the outputs Reply To: H90 double the outputs
#182248
viktoraigner
    What, inserts add latency? So, if I have an external reverb pedal (set to kill-dry) in a stereo insert (set to 50% mix) at the end of the chain it adds 3.8ms to my dry signal within the H90? I can understand that reasoning if using the inserts for insert effects (where you might mix the dry signal to an overdriven wet signal) but not for send effects (where you only add the fully wet delay/reverb tail to the dry signal). Can we therefore please make the added latency switchable?
