Home Forums Products Stompboxes H90 with 2 synths on different outputs Reply To: H90 with 2 synths on different outputs
#182441
joecozzi
    It’s not possible to use both presets for two distinct signal flows as you’ve described. The closest you can get is using Dual mode and loading one preset on each path. Path 1 goes In 1-2 to Out 1-2. Path 2 goes In 3 to Out 3. This video explains Dual mode: https://youtu.be/0G_WtfUatSc?t=195&si=m_GwLjL2aLrPxsBQ
    What you can do is connect a synth to 1-2 and another to In 3 and have them both go through both presets and get mixed to Out 1-2. Insert mode is better for making the H90 function like a mixer as described in this video: https://youtu.be/0G_WtfUatSc?t=1190&si=Sswgbo_1xX0a3cVz
