Home Forums Products Stompboxes CC control of H90 Insert bypass / active Reply To: CC control of H90 Insert bypass / active
#182508
mrspikesir
    I can’t use the toggle on/off precisely because it’s a toggle (!).
    This means that every time I send CC=127 to the H90, the Insert either switches On if it was Off, or switches Off it was On (ie. whatever state it was in as a result of the last CC message, it then switches to the other state when it next receives CC=127). CC=0 is ignored because it’s a momentary toggle (so it only responds to CC=127).
    Which means I can’t program a patch on my pedalboard (an RJM Mastermind) where the Insert is set to be Off for that patch; similarly, I can’t program a patch on my pedalboard where the Insert is set to be On for that patch. Because whenever my pedalboard sends this CC toggle to the H90, it’s simply telling the Insert to switch On if it was Off, or Off it was On.
    Whereas most MIDI controllable pedals will accept a command that says ‘bypass if CC=0’ and ‘active if CC=127’. In which case, I can program that CC for each patch on my pedalboard so it sends CC=127 if I want the Insert active, or sends cc=0 if I want the Insert bypassed. Every other MIDI controllable pedal in my rig works perfectly like this (Strymon Compradre, Boss EQ, Prostage Wahrytone and RJM Overture).
