Home Forums Products Stompboxes SWITCH TAPE TEMPO Reply To: SWITCH TAPE TEMPO
#182509
    Scroll down to the bottom of this link …
    https://cdn.eventideaudio.com/manuals/h90/1.8.6/content/system-menu/global.html
    … then reference the list at this link:
    https://cdn.eventideaudio.com/manuals/h90/1.8.6/content/appendix/global.html#global-mapping-chart
    If you are only using one switch connected to EXP/CTL 1 or 2, a mono TS cable will work.  For 2-3 switches, use a TRS stereo cable.
    In any case, calibrate your switches, to be on the safe side:
    https://cdn.eventideaudio.com/manuals/h90/1.8.6/content/system-menu/io.html
