Home Forums Products Stompboxes Mute volume with expression pedal Reply To: Mute volume with expression pedal
#182710
    I have logged your request for an option to fully mute the signal using an expression pedal.
    Do you just need to mute the signal fully when you are not playing? You could use the tuner to accomplish this. Press the A+B footswitches together to access the tuner, and it will also mute your signal if set to MUTE.
