Home Forums Products Stompboxes H90 insert loop latency Reply To: H90 insert loop latency
#182782
dannysomerville
I think I understand this but want to make sure. I plan to use dual mode in relay bypass and will use one path at the front of my pedalboard for pitch shift, compressors, etc. I suspect this would get used sparingly. The second path will be after my drives for reverb, delay, modulation and will be on most of the time.
If I have one path relay bypassed and the other path with 2 algo in series it will be 4.5 total
If I have one path relay bypassed and the other path with only 1 algo it will be 3.8 total
if I have one path with 1 algo and the second path with 1 algo it will be 7.6 total (3.8 x 2)
is the above correct?
