Home Forums Products Stompboxes H90 MIDI/Programming Questions Reply To: H90 MIDI/Programming Questions
#182851
    Correct. the H90 only receives PC messages 1-100 to load Programs from the currently selected list. You must go into the system settings or use H90 Control to select a different list, this cannot be done using MIDI.
    Using H90 Control it is very easy to make duplicate lists with variations of the different Programs you are using.
