Home Forums Products Stompboxes H90 connection to switcher- gigrig g3 atom Reply To: H90 connection to switcher- gigrig g3 atom
#183291
joecozzi
    I’m getting a small volume drop just enough to take the edge off the amp when the HD is in the Signal chain.
    A few questions to determine what could be causing the change in volume:
    -Are both H90 paths being routed to the front of the amp?
    -Is either path being directed to the amp’s effects loop?
    -What other effects are in the signal chain along with the H90?
    I have lip and lick with the drives in between.
    I’m not sure what you are saying here. Are you saying you have drives in between both H90 paths?
