Home Forums Products Stompboxes H90 MIDI – Two Questions Reply To: H90 MIDI – Two Questions
#183423
joecozzi
    You can exit Bank mode by using the mode toggle command found in the global MIDI mapping menu. It’s not possible to access the second page of Perform mode via MIDI, but you can use the Perform 1,2,3…6 options to access Performance functions on your MIDI controller directly.
